Hi there,
I am trying to add a filter based on a fixversion "5/1/2020 RELEASE" given to some of our current tickets.
I already tried the following :
version = "5/1/2020 RELEASE"
and :
fixversion = "5/1/2020 RELEASE"
But I am getting the following message : That it does not exist.
Maybe order by status as well ?
Hi Joao,
I tried the following on my instance and it executed with no problem:
fixVersion = "November 11, 2019 Release"
Maybe it is the / mark in your release name. See if you can modify the release name and then run again.
It turned out to be a typo - fixversion = "5/1/2020 RELEASE" this works
hello @Joao Borges
the jql fixVersion = "my fix version" works fine.
Can you check that this version exist in your project. When you make a search this field have autocompletion, you can use it to make sure that you're selecting the good version.
