Hi guys,
i want to add some checklist fileds on every sub tasks discription with different values
for example check the image
created a subtask name Fruits (Q1-Q3) and a checklist for it
Check the colour,Check the Taste & Check these value these are the default fileds need to be created on every subtask in the project but the extension which is (Q1-Q3) will be diferent in every task for eg. (A1-A3) , (B1-B3) and so on
so i have number of sub tasks which i need to create a checklist and need to mention the bracket field on every check list.
do i need to create any automation rule for it ? and how
kindly help me
Thanks & regards
Yash
I use issue checklist pro and I have it so when I create an issue or transition one I edit the field `checklist text` and I put
[ ] checklist item 1
[ ] checklist item 2
[ ] checklist item 3
and that seems to work flawlessly with the automations. I've never gotten the saved checklists to work for me :(
(default checklist based on type wouldn't work for my use case)
Anyways hope this is helpful!
Which checklist app are you using? I use Issue Checklist Pro which allows me to set a default checklist based on issue type. I'm wondering if your app allows you to do the same. If so that might be the right solution?
Checklist for Jira Cloud. Free, " yes tried with "Issue Checklist Pro" thanks for the Quick response
Hi Yash,
You can set checklists per sub-tasks via Automation for Jira using Smart Checklist Pro.
Here are the detailed steps: Add Checklists to Subtasks while New Issue creation.
If you like you can also check out the Free version.
Feel free to contact us directly via smartchecklist@railsware.com.
Best,
Olena
