How to add comment field in customer screen in on demand JIRA
srinivasan radhakrishnan
September 10, 2013
I need to include the "Comment" field in customer issue screen in on demand JIRA.
Please share your knowledge.
Thanks.
Nic Brough -Adaptavist-
September 10, 2013
Make sure the user has "comment" permissions.
September 10, 2013
Hi Nic,
Thanks for update.
I not able to configure the "Comment" filed in test screen in on demand JIRA.
September 10, 2013
Again, look at the permissions in the project.
Comments are NOT a "field" and are not configured in the same way as fields. Their prescence is mostly controlled by permissions. So look there.
Christian Czaia [Decadis AG]
September 10, 2013
The field is being displayed by default in every edit screen. You can't add it to the "create issue screen" though. Other than that, do what Nic suggests. Check the permissions...
Carolina Gómez January 29, 2014
Just create an empty screen and add it as the transition screen
