We use Jira for user stories as well as defect tracking and testlink for test planning test case development and execution. We've used the integration between jira and testlink to add the link to a jira defect within testlink. That's pretty cool.
However, there does not appear to be a way to link from Jira to a testlink test case. Jira Users (developers) have to open testlink separately to review acceptance test cases. Ideally a Jira user could add a link from Jira to Testlink.
Perhaps I'm wrong. Does anyone know if this exists
TestLink does provide direct links to test cases. To see them, view a test case, then click the icon to the left of the test case id & name to see the link. They look something like http://server-name/linkto.php?tprojectPrefix=project-prefix&item=testcase&id=test-case-id.</em<>>
I just wish TestLink would also provide direct links to test suites.
i am also looking for a solution to this , any pointers willbe helpfull - Rama
Do we have any solution for this?
do we have also full traceability with the User Stories when we use Testlink? – I think this it’s crucial to be able to link User Stories with test cases and be able to generate test-reports on a user story level.?
What is the single most important features that Test link users would want to see in the front end of the open source MobileApp for Testlink ?
Hi Tom,
Have you integrated the User Stories in Jira with the Requirements in TestLink?
You can create link to tescase: http://www.teamst.org/forum/viewtopic.php?f=5&t=1539
but how I can automatically add it to Jira bug
We use Testlink too. It doesn't appear possible to build a URL directly to a test case at all, so I can't see how you'd be able to link to one in Jira.
