From JIRA, how can I as an admin add multiple users (say from a .csv file)?
Hi Baljeet,
Unfortunately you can't import users using csv files. You would need to create manually the users or you can set a user directory to allow the users to sign up by their own. The only way you can add users using csv files is using the Crowd application.
Best regards,
Michael A.
