I am working on a JIRA plugin which gets external links. I want to add/ remove those links from JIRA ISSUE. How can I do that programatically?
Please explain more about what you are trying to achieve...
I want to help, but you are not clear enough
@Nir Haimov I am trying to integrate JIRA with test result of other tool. As a part of that I am writing a Jira plugin. Now as a part of that, the tool will call a servlet API of JIRA plugin and will pass the test result uri. I want to associate the test result uri wth the JIRA issue. There can be 1 or more such links.
@Nir Haimov I am looking for internal API for this rest api
POST http://localhost:8090/jira/rest/api/latest/issue/TST-1/remotelink
from https://developer.atlassian.com/server/jira/platform/jira-rest-api-for-remote-issue-links/
Because if I want to call it I will need a http client. But I am within JIRA process space, so looking for an direct JIRA API
OK,
I understand now what you are trying to achieve.
But it seems like you got the solution (the link you sent me).
Where are you stuck in the process?
I was looking for the JAVA API instead of REST API. At last got it from https://developer.atlassian.com/server/jira/platform/creating-remote-issue-links/
@Nir Haimov Now instead of showing the links under External Link section, I want to show it under a custom field or a custom section (if possible, have a custom section to show those link) along with a add button and a delete button
Follow this tutorial:
https://developer.atlassian.com/server/jira/platform/adding-content-to-the-jira-view-issue-page/
It will guide you to create a section in the issue view screen.
Once you will create the section just set it content to be your links and add any additional functionality you want
@Subhajit Bhuiya you are welcome :)
If i solved your issue and there is nothing more you need, please close this question by marking my answer as the solution.
