How to add the help in the custom field in jira
Manu Mishra
I have a requirement where i have to add the help (?) icon right next to custom field in create screen. When someone click on the help icon, it should display the information about the custom field, the way it shows in the issue type field.
Vasiliy Zverev
December 8, 2016
Into admin panel/issues/custom field  find your filed and fill description section
Manu Mishra
When i am doing it it is showing below. Means the information is showing below the custom field. I want the information should be displayed in right. e.g..
<custom field>__________<Help Content>
Nic Brough -Adaptavist-
December 8, 2016
Most fields don't support the ? - that's for the more complex help people may need with system fields that do clever things.  You need to put your help in the simple description field as Vasiliy says.
Vasiliy Zverev
December 9, 2016
So, you could try some html into a description. It could by some html element with description into title attribute.
Manu Mishra
Could you provide me the same of html element?
Manu Mishra
Even if i am putting the help in the description field, the help is showing below the custom field. My requirement is to show the help in the right side.
December 9, 2016
Yes, that's what we said.  That's where the help goes for most fields.
You need code to do it differently - a new way to draw up the fields and some way to enter and store the text you want.
Manu Mishra
Vasiliy Zverev
December 10, 2016
You could start with label html element
