How to add users using Python ?
onebuckethuso
March 7, 2018
Hello people this is my first question.
I've been looking for the answer all this morning.
I'm using jirapy extension to use jira API. I've successfully connected to the system and created a new user like;
jira.add_user(huseyin_test, huseyin@jira.com, directoryId=1, password=None, fullname='Test Hüseyin', notify=True, active=True, ignore_existing=False)
The problem is when I add a new user I can't assing an organization to the new user.
guess directoryId is the thing I'm looking for.
If it is, how can I learn directoryId's of the organizations ?
Regards
Hüseyin
Mohamed Benziane
Hi Hüseyin,
Here a documentation about organisation and API, you can try to call /rest/servicedeskapi/organization, this will give you all organization with their names and ID's.
You can use the JSON library to deal with the content you'll receive.
Hope it helps
Regards
