How to add watchers to a jira ticket starting from the email in a cascading cf
DOMENICO TROISI
December 19, 2018
Hi to all,
in a cascading custom field (opening mask) is contained one or more email of jira user. Is it possible, to add all the users contained in the second field of cascading as whatchers of a ticket via script post function?
I believe that from the email it is necessary to extract the user code before adding it as a watcher.
Many thanks! Regards,
Domenico
Carmen Creswell [Adaptavist]
December 19, 2018
Hi Domenico!
Here is a way that worked in my instance:
import com.atlassian.jira.bc.user.search.UserSearchService
def cfValue = customFieldManager.getCustomFieldObjectsByName("CascadingSelect")[0].getValue(issue)
def addresses = cfValue.get(null)?.childOptions*.value
def watcherManager = ComponentAccessor.getWatcherManager()
def userSearcherService = ComponentAccessor.getComponent(UserSearchService)
def theUser
for (def i = 0; i < addresses.size(); i++) {
theUser = userSearcherService.findUsersByEmail(addresses[i])
// Using theUser[0] because the User is an ArrayList of a single ApplicationUser
watcherManager.startWatching(theUser[0], issue)
You'll just need to change the name of the Cascading Select field to the name that matches the one in your instance.
