I had downloaded atlassian trial version and created a classic project
[Project name : Demo1]
From Settings -> Issues -> Created a workflow [ Work1] -> Added the workflow to workflow to following workflow scheme [Test work1]
I want to link my workflow scheme [Test work1] to my project [Demo1]
In your documentation , I found under project settings -> we have menu Workflow to link
But in case of my project , workflow menu is not seem to be enabled.
Can you guide me on how to link the workflow scheme to project
Followed my Steppes GO to that Project>WorkflowYou can select the Scheme OF Your Creating Workflow
On your Project settings, go to the workflow, and to the right side you should be able to see below buttons:
You can click on 'Switch Scheme' to assign your newly created workflow scheme.
