How to apply same statuses for all issues?
Lukas Wrede February 16, 2014
I've created several projects. Default status is "Open". However in one project status is always "To do" instead of open. Why is that different? How can I change that? I want to have the same status words in all projects.
Mauro Badii
February 16, 2014
Hi Lukas,
It will depend on the Workflow. Use the same workflow for different projects and you should have the same Statuses. :) If not you can edit the workflows to apply the text you want.
Mauro
Thanks Mauro, I've finally solved it. I needed to switch back to default workflow in the project settings. Settings > Project > Workflow.
