×i have a project in which tasks are created after that the task i choose is duplicated in a desired project from automation, i want to assing the duplicate task dependin on the value of a field.
i try this in the project where task are created:
also in the project where the duplicate issue creates, i try this:
Since your second automation is triggered by the first one, make sure that you have checked this check box under rules detail.
Hi @gestion didcom ,
What's the issue you are facing? Was there an issue with the assigning the ticket with the 2nd automation configuration?
-Ben
