How to auto-assign issue using mapping
BartłomiejS March 5, 2013
Hi there,
Perhaps I miss something but haven't found solution so far...
we need to automatically auto-assign issue right after its creation to a dynamically chosen user on the base of reporter.
To choose the assignee some mapping is needed. Every reporter has some default assignee independently in which project/component issue is created.
For example
User1 -> Assignee1
User2 -> Assignee1
User3 -> Assignee2
User4 -> Assignee2
User5 -> Assignee3
and so on...
Perhaps it could be done on the base of user properties but I have no clear idea or solution to this problem. Could you please help me? :)
thanks!
Henning Tietgens
March 5, 2013
You can use the Script Runner plugin to script a postfunction, where you map the reporter to the assignee.
BartłomiejS April 1, 2013
we came back to the subject after a while and one more condition appeared... we need to get some hints for determining default assignee using external oracle datasource... i haven't found a solution on how to access external DB using script runner so far... any help would be appreciated :)
Henning Tietgens
April 2, 2013
Using something like this you can access an external database:
Sql sql = null
try {
	// Get Context to connect to DATABASE as a datasource
	Context ctx = new InitialContext()
	if (ctx == null) throw new Exception("No Context found!")
	DataSource ds = (DataSource) ctx.lookup("java:comp/env/jdbc/DATABASE")
	if (ds != null) {
		sql = new Sql(ds)
		sql.eachRow(sqlStatement) { row ->
} catch (Exception e) {
	e.printStackTrace();
sql?.close()
The datasource DATABASE has to be defined within <Context> section of context.xml in jira/conf similar to something like this:
&lt;Resource name="jdbc/DATABASE" auth="Container" type="javax.sql.DataSource"
username="user"
password="password"
driverClassName="net.sourceforge.jtds.jdbc.Driver"
url="jdbc:jtds:sqlserver://10.192.168.1:1433/test"
/&gt;
After changing context.xml you have to restart JIRA. And you have to use driver matching the database system used.
Henning
JamieA
April 3, 2013
good info on using a datasource, alternative method is here: https://answers.atlassian.com/questions/154110/script-runner-external-oracle-database-support
RambanamP
March 5, 2013
using post function you can do this
but i need to script it somehow right?
RambanamP
March 5, 2013
no, just you need to configure postfunction at create transition step
ok this step is simple... but how can i freele choose assignee on the base of different reporters there? it'c completely customized behavior. i don't want to choose assignee from the list, because it depends on reporter - as i wrote in teh first post.
RambanamP
March 5, 2013
develop your own custmized postfunction, then add condition based on reporter and assign to the default assignee of the reporter
