I would like to have a sub-task created on the linked JIRA issue when I create a review. Is there any way to do this?
If not, what is the best way to ensure that a code review is completed for an issue before it can be completed?
I'm not sure if you can create a sub-task when you create a review out of the box. I have to poke around a bit on that one.
However, your second request I know is possible:
JIRA's workflow allows for a number of built in conditions that allow you to restrict execution of a workflow transition, (i.e. moving an issue from In Progress to Resolved).
You can have a look at Configuring Workflow and JIRA's built in conditions for more on what's possible, but the two options that might work in your case would be here I think:
No Open Reviews Condition |
Only allow the transition to execute if no related Crucible reviews are still open against the issue. |
None |
Unreviewed Code Condition |
Only allow the transition to execute if no unreviewed changesets related to the issue exist. |
None |
Thanks! I think if I can accomplish #2, I can effectively accomplish #1.
No problem. Good luck.
