Dear all,
Is there a way to automatically open JIRA issues in project, for jobs that have failed to execute?
Best Regards,
Are you a JIRA Cloud or JIRA Server user? What other Atlassian tool are you using for your code?
Thanks for your reply. We use JIRA v7.3.1 Server version. We have integrated: Confluence, bitbucket, Nexus, jenkins, Tempo and People editor.
https://confluence.atlassian.com/bamboo/creating-jira-application-issues-from-a-build-289276958.html
Check out the doucmnetation. The latest version of Bamboo has that capability if linked with JIRA Software.
Thanks for your reply. I would like to know if there is the possibility of automatically open JIRA issues in projecs without installing more components to the Jira.
Thank you very much
