How to block changing status if jira issue has status DONE?
Ilona Marczak
July 18, 2019
Hello, I need to block option of changing status when ticket is in status DONE. How can I co this? Thank
Alexey Matveev
July 18, 2019
You should add workflow property to the Done status:
jira.issue.editable = false
Mirek
It depends on your role in Jira, workflow and platform that you are using (Cloud or Server). If using simplified worflow it might be not possible. You would need to have a workflow that have clearly defined transitions (not all to all) then you might block those that are going from DONE to previous statuses.
Suhas P
July 18, 2019
You could simply remove all outgoing transitions on the status DONE.
