Is there a way to display information of my linked issues and their linked issues in a chart? Like burn down/up chart for a sprint, but instead of sprint, I want to use my parent liked issue.
Also I would like to see, created vs. resolved issues, plan start-end, delta of remaining effort...
There is possibility to combain those information in a jira structure, but only in the table view. I would like to see those information in charts
Can this be solved with the arsenale dataplane add-on? I have founded the 'Current Issue Values' report with value of 'Epic Link', and segment by 'Status', but nothing more like linked issues, time estimations...
Hi Tatiana,
While Structure itself cannot do arbitrary charting (Structure.Gantt notwithstanding), there are apps there that can do that. EazyBI, for instance, is a very powerful tool for charts and diagrams, allowing among other things to manage simple hierarchies. It can even integrate via REST API with other apps.
Egor Tasa
ALM Works
You can try AIO Reports and Timesheets for Jira app:
It allows for reporting on Linked issues very easily. In case of any questions please feel free to email us at support@aioreports.com
