Is there any way to bulk export more than 1000 issues through CSV file. Is there any possible way this can be achieved. Any suggestions will be appreciated.
Jayaram
Thats the limit. There are workarounds:
- API
- third party plugin
You can vote here:
https://jira.atlassian.com/browse/JRACLOUD-25493
Regards
Use the Better Excel Exporter to export more than 1000 issues to Excel, then save to CSV.
(Discl. it is a paid and supported app developed by our team. Free for 10 users!)
Hi @Jayaram Kuraba ,
The 1000 issue export is the limit for the Cloud CSv export
To view more issues in excel you can use the Jira Cloud for Excel :
This is not a paid add-on just requires your use to authenticate Excel to access the issues on your behalf
