How can i display more than 2 values or a names in the bar chart. consider, i have specific impacted CI need to select and also i have resolution by category. how can i get the list of those and displays in bar chart ?
Hi @Mukesh Nadar ,
Welcome to the community. I just saw the date on this was in early june so maybe you have found yourself an answer already.
Can you tell us a bit more on which barchart you are working with? Inserting some screenshots will help us help you a bit quicker.
For CI's - are you using Assets perhaps?
For bar chart: do you mean the timeline view of your jira work managment project or do you mean a bar chart on a dashboard displaying data from your work management project?
You can for example use the issue statistics - gadget on the dashboard to present a sort of bar chart of any field on a ticket.
Also you can extend Jira with addons specifically made for enhancing the reporting capabilities.
best of luck
Lisa
