How to call web service using script post-function?
kunti pawar May 10, 2018
I am using script runner and I want call SOAP web service when I click on To Do workflow
Prakhar Srivastav {Appfire}
May 10, 2018 edited
Hi @kunti pawar
I am not sure if it is possible using scriptrunner as you have to create stub classes from wsdl of the respective SOAP service.
If you develop plugin in java using atlassian sdk then it will be possible to create such a post function.
Regards
Prakhar
kunti pawar May 14, 2018
Actually I want call web service on workflow trigger (To Do to in progress)
So I am expecting any simple example to call web service using script runner
Like • Johannes likes this
Johannes
Hi @kunti pawar ,
have you found a solution for this?
