How to change JIRA_HOME consistently when using Atlassian´s Docker Image for JIRA
Christian Schlaefcke
when deploying Atlassian tools I am using docker images for a while but always created my own custom docker images. For improving and simplifying maintenance I want to switch to the docker images provided by Atlassian now - I like the idea of configuring the whole system with just a few environment variables.
The Jira image provided by Atlassian is using /var/atlassian/atlassian-data/jira as JIRA_HOME by default and the same directory is being used as Current Working Directoryjira.path.attachments and user.home (found in Administration > System > System Information).
My own image has used /opt/atlassian-home as JIRA_HOME so far - I only have one Atlassian tool per docker container and my system is heavily dependent on this path. I also checked this Atlassian KB article (Setting your Jira application home directory).
I assumed that this could be changed easily just by setting the JIRA_HOME to the desired path in my docker-compose.yml in the environment section:
services:
jira:
container_name: my-jira
image: atlassian/jira-software:8.20.27
environment:
- JIRA_HOME=/opt/atlassian-home
- JVM_MINIMUM_MEMORY=6g
- JVM_MAXIMUM_MEMORY=10g
But unfortunately this is only affecting the JIRA_HOME setting itself and not the Current Working Directoryjira.path.attachments and user.home variables - they stick to /var/atlassian/atlassian-data/jira which is causing quite bad problems to my scripting and other customizations that rely on the path /opt/atlassian-home
I checked the docs of the Atlassian docker image but cannot find any solution to my problem. Any hint on how to fix this would be very appreciated!
Best, Christian
Artur Moura
November 28, 2023
Hi @Christian Schlaefcke
I believe you can't change the home path if you don't have a customized image. However, I would recommend you use this Jira Docker - Advanced Configuration to create a customized image based on the Atlassian Image as a source of your customized image.
I'm mentioning this because the JIRA_HOME variable is defined in the Dockerfile, and even defining the variable in docker-compose will have no effect.
Please let me know your thoughts.
Best, Artur
SERVER
VERSION
8.20.27
