How to check for dropped connection and reconnect?
Torsten Feld
January 24, 2015
I'm connecting to JIRA with jira-python (0.32). At some point, the connection to the JIRA instance is lost. How can I check if the connection dropped and reconnect? Do I just have to "jira = JIRA(...)" again?
Jeff
August 9, 2016
What operation are you performing which is holding the connection to JIRA open for long enough that the connection is timing out? Is it possible for you to avoid that operation?
