How to clear Flagged field through post function
Algimantas Stancelis
April 4, 2016
I've tried `Set Field Value to constant or Groovy expression` function and setting Raw value to empty value. It doesn't remove the flag.
Christian Czaia [Decadis AG]
April 4, 2016
Try the free addon JIRA suite utilities and the clear field value post-function:
https://marketplace.atlassian.com/plugins/com.googlecode.jira-suite-utilities/server/overview
Deleted user April 4, 2016
I would think using the built in post function; 'Clear field' option and selecting the 'flagged' field would work. Have you tried that?
Opps, sorry - it's been so long that I forgot it's a plugin - Christian's right; install the plugin, then you can do what I outlined.
