Hi @Rim Budrys
If you need to go further, we developed an application called Copy & Sync that allows you to copy an Epic with all its child issues with a single recipe.
In a nutshell, you will be able to:
It's really easy to use and to configure with just a few clicks.
If you want to keep your Automation, you can trigger the recipe directly via Automation through API.
Feel free to give a try, it's free under 10 users and we have a 30-Day trial policy.
I'll be glad to help!
Regards
Thibaut
HI @Rim Budrys
Welcome to the community. This is Majid @ Exalate.
I am not sure if you were able to solve this or not, but using a synchronization solution liek Exalate you can sync these Epics bi-directionally to another Jira project (on the same instance) or a totally different Jira system as well.
Hope it helps.
Majid
Hi @Rim Budrys and welcome to the community!
If you are willing to use a third-party app, our Deep Clone for Jira can help you clone whole issues hierarchies (Initiatives ⇒ Epics ⇒ Tasks/Stories ⇒ Subtasks) with our Epic/Tree Clone feature.
Navigate to the issue you want to clone
Click Action menu ••• > Deep Clone
Select Epic/Tree Clone
Configure and create your Epic/Tree Clone
Soon, you will also be able to create presets for Epic/Tree Clones, so you will be able to quickly trigger an Epic/Tree Clone from the Actions menu ···. This will also allow you to trigger an Epic/Tree Clone via Jira automation.
We even have planned a webinar to introduce the feature. You can sign up here if you are interested.
Right now your child issues are cloning but with "Copy from Parent", it means they are attempting to copy the Epic Link of their parent which doesn't exist yet. Here's how I would address it:
Add a Create Variable action just after your Epic clone:
Then in the Clone Issue within your branch, change Epic Link from "copy from parent' to {{varEpic}}
Unfortunately {{varEpic}} cannot be set in Epic Link field in UI considering it is a dropdown.
I was able to get cloned tasks to be linked to new cloned epic via "Relates"
However I need new cloned tasks to have a newly cloned epic as their parent instead.
You can absolutely use a smart value in the Epic Link field. As you start typing it in, you will be prompted to use it as a smart value.
