I am new to this Script Rest endpoints and i am looking for on a sample script on how we can create/clone an issue using this Rest end points.
Can anyone help me or guide me on this
Adaptavist has a guide on this with some good examples: ScriptRunner - REST Endpoints.
Combine that with the code in Create an issue in Jira - Adaptavist Library and you'll have the starting points for learning how to create an issue via a scripted REST endpoint.
How do we pass multiple customfield parameters while creating the issue?
Going off that example, you'd use:
issue.setCustomFieldValue(CustomField customField, Object value)
for each of your custom fields you want to set. The object defined in
def issue = issueFactory.issue
is a MutableIssue object, so to find all the methods on that object, see this doc: https://docs.atlassian.com/software/jira/docs/api/7.1.9/com/atlassian/jira/issue/MutableIssue.html
