We don't know what you've tried, how your system is configured or what errors you are getting.
Thank you for your response. I am using PUT method and updating comments as well as state set to done. Below JSON I have tried.
"update": {
"comment": [
"add": {
"body": "comments"
"transition" : {"id":"31"}
Transition id for the value 'DONE' is 31.
When I run this , I am getting 201 but status not changed only comments are updated.
So you are making two separate calls to the REST API? One for comment and one for transition?
What happens if you put the transition first?
Ok, what if you just try the transition alone?
You also say "transition id for done is 31" - are you sure that is the transition ID and not the status id for Done? The id can easily vary by workflow, and 31 is used in a lot of examples, so I've got to check you're not just copying that without checking the workflow.
It is correct transition id only , i verifed. I also tried with transition id alone, this time I get 400 code and in response says method failed
Ok, that's better, we're getting a proper error message. What does the rest of it say?
Hmm. What type of call is it? put/get/etc?
somehow the comment i entered is deleted?
I am using PUT method.
Do I need to use POST method to change the status field?
Also will the transition id differ for for DONE status, in one of the issue, I am getting the transition id as 41, another issue is showing 31. Will it differ for each issue based on current status?
Yes, try post instead.
You don't normally set a JIRA issue status in most cases. A status change is the result of a transition, so it'll be done for you when we can get this to work!
Transition IDs vary, yes. Within a workflow, the ids will always be unique, but the transitions can be shared. You might have "done" with an ID of 31 that is used on Open -> Done, and Dev -> Done, but then have 41 being the transition from Test -> Done.
