How to close the ticket with updated using scriptrunner Groovy script.
mohit panwar July 8, 2021
Hi Team,
I have a requirement to close the particular issue type of my project using some comments. Need your help to have a code in Groovy Script. Thanks in Advance for your help.
mohit panwar July 10, 2021
Thanks, Martin for the response.
Below is another question that is on high priority. Please give some guidance I am new to script runner.
I need some help. How to get the value of the custom field from the issue type. Then printing and using that variable further.
I have an issue type with the name "TEST1-5". when trying to print the value for issue and csChangeArea I am getting "NULL" value. Please help and suggest how to use th
When
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.issue.ModifiedValue;
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder;
def issueLinkManager = ComponentAccessor.getIssueLinkManager()
def issue = ComponentAccessor.getIssueManager().getIssueByCurrentKey("TEST1-5")
def csChangeArea = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectsByName("Username")
log.info("My script variable new value : " + issue)
log.info("Custom field value : " + csChangeArea)
Martin Bayer [MoroSystems, s.r.o.]
Hi @mohit panwar , create a new question for new topic, please. If you mention me, I will get notification and I can check it :)
