I would like the parent task to change automatically the status for 'in progress' once its sub-task is set to 'in progress'. How can this be done?
Thank you in advance
Karol
Hey @Karol Baryło
You can do this by using Jira Suite Utilities if you are on a Server instance of Jira.
If not, I'll leave this for someone else in the community to answer if they have a suggestion. Good luck!
Thank you for reply Brittany. I am using Jira cloud. Greetings! Karol
