IT seems to ignore the on-screen fields and just export whatever he wants.. .
Actually, for mine, I need to set Columns to "My defaults" (NOT Filter) -- whatever is selected under "My Defaults" appears in the exported file. Doesn't matter what I have in the Filter option.
This did it for me! 👌
Thank you! 📌
How do you navigate to this UI to set "My Defaults"? I am on the Sprint Reports -> View In Navigator page and attempting to "Export to CSV (my default)" and I want to change what my defaults are. But I can't find this in the UI. Please help!!
I found the solution... trivial actually.... export is using the field selected in the filter tab rather than the fields that are displayed (columns --> Filter tab on the top right hand side , see below screenshot
Hi @Sharon Cohen-Ofir I dont have the filter option? mine just shows this:
Thus, i do not have the option to export to current fields. Anyone had the same problem?
I dont have the option listed for 'Current Fields' only All fields
any solution on fixing/adding this?
The same issue is described last year on this page:
https://community.atlassian.com/t5/Jira-Software-questions/Filter-export-returns-incorrect-fields/qaq-p/1146158
I have to set the default column view to "Filter" and leave it there for the account I use to download the issues.
Hi, i faced similar issues and then started importing csv files using Power query filter for Excel. still time to time i need to visit and tweak query steps, however it is much less painful then fixing manually fixing spreadsheet each time.
I have the same issue. I'm displaying columns based on the 'Filter' view
But no matter how I export; CSV (current fields), Excel (current fields), or even the Open in Google Sheets - It's pulling the columns from the 'My defaults' section.
I was able to resolve by clearing my browser cache. I cleared the last 4 weeks on Chrome. Did the trick for me. Hope it works for you too!
I must adjust my above work-around. It turns out that manually adjusting the JQL is what is breaking the column sync. If I just run the filter as-is, then the columns export correctly. Still a #bug though
This work-around is not working for me. Do you have other ideas?
sorry Luiz, nothing beyond the typical default troubleshooting. The issue hasn't recurred for me in a while. I suggest getting the filter the way that you want it, saving (or saving as), closing out the window, clearing cache, re-opening, and trying the newly saved (or new filter) I do think there's a bug here and one of the many instances of @Support @Ryan Robert @Support should take a look at this, and reach back out to us.
Hi. Am am selecting columns in the columns tab, and choosing CSV (Current Fields) AND YET, the exported CSV file still has many more columns than the 5 I have selected for display. I want the export to match the display. How can I control that?
When you choose to export the current field, the result still export all the fields?
Hi!
I have the same issue:
1 - I already defined the columns I want in "My Default" option.
2 - But when I try to export the CSV comes with the columns defined in the "Filter" option.
How to fix it? (if possible).
THX!.
