×we have a source project called ABC and we have a sprint enabled in that particular project.
Now want to copy same set of issues with sprint status and same sprint name into another project called XYZ.
is there any way to do this ?
Hello @CHINNAMUTHEVISAI.SATYANARAYANASHARMA
As you plan to create a copy of the issues, I would suggest using a CSV export from project ABC and then import to project XYZ.
But with this approach, the attachments (if any) might not be copied. Please refer to this article.
Also, the issue history is not migrated in this approach.
In case you need to move/ copy the issue history as well, then you will need to explore the Atlassian marketplace for a 3rd party plugin.
I have used the 'Configuration manager for Jira' plugin to move issues across different instances.
Kindly accept the answer if this helps.
-GG
