How to copy Watchers and comments in script post-function
Jeremy Schrecengost
I have a script post-function that will copy an issue to a new project on transition based on some variables.
I added in some Additional Issue Actions in (copying the issue assign) using this code
issue.assignee = sourceIssue.assignee
Is there a way to copy over comment or more importantly watchers? I have tried issue.watchers but that is not a valld data source for issue
If there is not a way can I get a list of the functions for the issue (like a wiki)
I CANNOT install any additional add-ons we have a locked environment, I can only use scriptRunner or default JIRA functionality
Vasiliy Zverev
January 24, 2017
Here is a draft for you. Initilise varialbles issue and source issue properly
import com.atlassian.jira.issue.comments.Comment
import com.atlassian.jira.issue.comments.CommentManager
import com.atlassian.jira.issue.watchers.WatcherManager
Issue issue
Issue sourceIssue
WatcherManager watcherManager = ComponentAccessor.getWatcherManager();
watcherManager.startWatching(watcherManager.getWatchers(sourceIssue, null), issue);
CommentManager commentManager = ComponentAccessor.getCommentManager();
for(Comment comment: commentManager.getComments(sourceIssue)){
    commentManager.create(issue, comment.authorApplicationUser, comment.body, false)
Jeremy Schrecengost
I am having 2 issues with this code.
The first one is I am getting an error on this line
Also I tried to remove the watchers section and just use the comment section and I am not getting any errors in the code but the copy and everything is failing. Since I do not have any logging setup I do not know the reason for the fail.
Also I am on JIRA v6.3.12 if that changes anything
Vasiliy Zverev
January 25, 2017
Hm, try this one
Issue issue
Issue sourceIssue
for(ApplicationUser user: watcherManager.getWatchers(issue, Locale.FRANCE))
    watcherManager.startWatching(user, issue);
Sibel February 14, 2019
I have tried to use the following (Tested via Script Console)
//Issue issue
//Issue sourceIssue
Issue sourceIssue = ComponentAccessor.getIssueManager().getIssueObject("SUP_TR_NOTIFY-1")
Issue issue = ComponentAccessor.getIssueManager().getIssueObject("SUP_TR_NOTIFY-2")
And the error is :
 2019-02-14 16:56:24,393 WARN [common.UserScriptEndpoint]: Script console script failed: java.lang.NullPointerException at com.atlassian.jira.issue.comparator.ApplicationUserBestNameComparator.<init>(ApplicationUserBestNameComparator.java:23) at com.atlassian.jira.issue.watchers.DefaultWatcherManager.getWatchers(DefaultWatcherManager.java:144) at com.atlassian.jira.issue.watchers.WatcherManager$getWatchers.call(Unknown Source) at Script148.run(Script148.groovy:14)
