How could I copy a project from Developer Instance to Production instance with:
Please help.
If this is a new project, then you can perform an XML backup, and then do a Project Import: https://confluence.atlassian.com/jira/restoring-a-project-from-backup-185729444.html
If this is an existing project, then there are some third party add-ons which do this: https://marketplace.atlassian.com/plugins/com.awnaba.projectconfigurator.projectconfigurator
https://marketplace.atlassian.com/plugins/com.botronsoft.jira.configurationmanager
And they are working with export from one instation to another instation ?
The add-ons? Yes I think that is their point, but I haven't used them myself. I would check their documentation and maybe do a trial to understand if they would serve your needs.
