How to copy/paste product management/build with new start date?
James Nixon
November 12, 2021
Hello
we are currently using Jira for multiple one-off projects and it works well. However, I would like to create a template for a repeat product build (ordering, build, software implementation, testing etc) where the template is just copied with a new start date and then triggered. Can this be achieved?
J
Tushar Bhatia
November 16, 2021
Hi James,
You can do this when you create a new project by checking the “Share settings with an existing project” box. Note - this option isn’t available on the free plan.
For more detailed explanation take a look at the docs here - https://support.atlassian.com/jira-software-cloud/docs/create-a-new-project/
Hope that helps!
FREE
