How to create Custom Agile Project which exists custom fields created by me?
Arun Salvi August 25, 2015
I want to create a Custom Agile Project which exists custom fields created by me, whenever I will create this Custom Agile Project custom fields should be by default added in newly created custom agile project.
Please share me the steps to create a custom project Agile type.
Nic Brough -Adaptavist-
August 25, 2015
You will need to write an addon to provide a new "project type" (see https://developer.atlassian.com/jiradev/jira-platform/projects/tutorial-creating-a-project-template ) or use an addon that provides project copy type functions.
Arun Salvi August 26, 2015
I don't want to use code level customization, and also which addon you are talking about please share me the steps. I already purchased licence. Also tel me how to create custom field which is already added by default to newly created project ?
August 26, 2015
Your requirement is for a new project type. You can only do those with code (add-ons are code written by someone) Have a look for project creator and project copy in the For custom fields that will be added to new projects, you need to use a project type that uses the global default schemes, and create custom fields with a global "context". See https://confluence.atlassian.com/jira/configuring-fields-and-screens-187859099.html
August 26, 2015
Bother, sorry, have a look for "project creator" and "project copy" in the marketplace: https://marketplace.atlassian.com/
