I want to migrate Salesforce oppty into jira issues so i need to create a Custom field in Jira,which will have alphanumeric values, as salesforce will have id's that are alphanumeric
Hello @krishna jaju
Is your question about what type of field to use, or the process for creating the field?
What type of field?. Like when i go in issues--> Custom Fields--> Create Custom Fields.
There i can see various Data type but not sure about the Datatype which will take alpha numeric value. My Value is like this 0065g00000Xpq1TAAR
The Dataypes provided there are as follows:-
Checkbox,DatePicker,Datetimepicker,Labels,number,paragraph,radiobuttons,select list,select list(Multiple & single choice),Short text(plain text only),URL field,User picker.
Kindly help me out.
Hi @krishna jaju ,
welcome to the community.
A single line text field can have any alphanumeric value.
Please see the documentation on how to create custome fields and add them to your project's screen schemes:
https://support.atlassian.com/jira-cloud-administration/docs/create-a-custom-field/
Hope that helps.
