To create an forge app which has an dashboard it contains jira gadgets and their status for which the user will won't get into the jira page for the every time they can easily get to know all the jira status in confluence page.
Hey @Manimaran
You can create an app that will work with both Confluence and Jira so that you can display Jira data on a confluence page or vice versa. Why not start by checking out this blog https://blog.developer.atlassian.com/how-to-build-a-cross-product-forge-app-for-jira-and-confluence/
If you're very new to building Forge apps, we've just started creating a self guided learning resource to help you on your journey - it's called Forge Quest.
I hope this helps you in the right direction for creating your app!
Mel
Hello @Manimaran
That is a seriously non-trivial question. It's the equivalent of asking "How can I create a rocket ship that uses liquid propellant and takes someone to the moon".
The About Forge page has all the information about the basic concepts of the framework, various tutorials, sample applications and other learning resources.
Have fun on your learning journey.
