How to create a dashboard in Jira with worklog author field item
Venkat Pavan
August 11, 2025
To track the work using worklog author and worklog comments made by the issue assignee.
Rahul_RVS
Hi @Venkat Pavan
Welcome to the community !!
For detailed time tracking reports if you would be interested to explore a mktplace app, pls take a look at
Worklogs Time Tracking in Jira & Timesheets
With this add-on, you can easily add the worklog authors and time tracking reports as a dashboard gadget. Main features of the app -
  • Create time reports in real time by grouping & categorizing data with aggregation
  • Prepare your reports based on Project/Sprint/Issue Type/Assignees and various other filters
  • Group your data to build more meaningful reports
  • CSV Export
  • Dashboard gadget
  • Enter Time Spent for multiple issues from Timesheet screen. With Calendar view and Board view
You can also export worklog comments to a csv as shown in the screen shot below.
(Disclaimer: I am part of the app development team)
Nikola Perisic
Welcome @Venkat Pavan
You need to create a new filter that will contain worklogAuthor and worklogComment.
worklogComment is harder to fetch for current assignee. As a result, it would look something like this:
assignee = currentUser() AND worklogAuthor = currentUser() AND worklogComment IS NOT EMPTY
ENTERPRISE
