We have multiple projects that have same characteristic with same scopes and therefore the subtasks of each project are no different from the others.
Is there a way to pre-design a subtasks and whenever we create a be project, the whole subtasks will be created automatically without the effort to create every single one subtask.
If you truly need to have separate projects, you could also create a CSV file of the items you want to pre-load into the project, and then use the External System Import feature to create the items by importing the CSV after you create the project.
Correct.
While Jira Software does not explicitly offer sub-projects, it is possible to structure your project in a way that it represents the hierarchy you need. Within Jira Software projects, you can add multiple epics, which can act as a "sub-project" that can be divided them into stories/tasks and sub-tasks.
The default hierarchy contains:
Although they are not hierarchy mechanisms, you can also complement the structure by using other grouping tools such as components or labels that allow you to easily find related issues.
If you need more hierarchical views, you should consider an app like Links Hierarchy, Structure, or others available in the Atlassian Marketplace.
Additional Information
The Atlassian app, Portfolio for Jira, offers the ability to create new, unlimited hierarchy levels as well as getting a 'big picture' view of your projects and tasks in Jira Software or Jira Core.
To create new hierarchy levels in Portfolio for Jira:
You can create as many hierarchy levels as you want in Portfolio for JIRA by following these steps:
Click here to read more about configuring initiatives and other hierarchy levels.
