Can someone explain how to create a simple project burn down chart?
We don't use sprints, so using the scrum burn down didn't seem to work. Also the Scrum burn down applies to only one sprint, I want to see it for the entire project.
If it's possible using sprints I have no issue with that, but then require to create sprints in the past to have the charts look correct as I have projects that are half completed.
Thanks.
This addon will help you https://marketplace.atlassian.com/plugins/com.kaanha.reports/server/overview
Hi ashish, I have this plugin installed. I will try to configure it to create a burn down. I'm not that familiar with it right now.
Do you know if there is an example configuration for it somewhere?
Thanks!
Follow this link it will help you https://www.jirareports.com/public/support/help
