I am asked to provide a report on how long did an issue stay in one status. E.g., how long did it take for the issue to move from 'Backlog' to 'To Do', or, how long did an issue stay 'In Progress' status?
We are using Jira Cloud version.
Does anyone know about it?
Thank you,
Hi @Donata.
There are 2 solutions for your issue.
Time in Status for Jira cloud automatically calculates the time spent in a specific status. It generates a report about the Time a task has spent in a particular status. Except for Time in Status report, you get Assignee Time and Average Time reports too.
Time between Statuses generates reports of the transition from status to status. So you can monitor how much time it takes for a task to move from one status to another.
If you have any additional questions, feel free to contact me.
Best regards, Mariana
Hi @Donata
Short-answer: There is no out-of-the box and easy way to do this. But, you could buy or build something.
Longer answer:
Best regards,
