I"m on a Zephyr for JIRA cloud trail and try to create a test (case), but it fails because the issue 'test' is not available from my pull-down menu.
Do I have to pre-define it before 1st use ?
I searched all the menus, but wasn't able to find it. Somewhere it is even said that with Zephyr issue 'test' is automatically created.
Can you help me ?
Kr., Michael
Hi Michael,
Follow following Steps:
And you are Done !!
Cheers
Regards:
Sopan Sagorkar
Hello Sopan,
We have to perform above on JIRA to add test cases on JIRA ?
Or Do you know how to write test cases using JIRA ?
Aniket
Hi Aniket To create TestCases you have to use "Zephyr"(Add-on to JIRA) because by-default JIRA don't have issue type as "Test"
