I added jirabot to my slack channel, now I want to create issues from jirabot in my channel
Hey, Santiago.
We don't have any information about any specific bot for Slack, in this case, you'll need to check with its creator. My bet is that it uses Jira's REST API to create/work on issues from Slack, the bot probably has some commands in order to do that(check for a "help" option).
If you are looking for integration between Jira and Slack, I recommend you to check this page:
It contains information on how to set up Jira to send notifications to users directly on Slack.
Maurício Karas
Excellent, thanks a lot Mauricio. Now I can decide many things in my team's workflow.
I'll see the REST API.
