Hi Maria,
Setup a screen that maps fields to correspond to your template.(including specifying if an information is required or not).
Add the newly setup screen to the create issue operation of the screen scheme of the project.
If you are not creating the ticket directly from JIRA then do let me know how they are being created so I can advise.
Hi Maria,
May I ask what you mean by template first?
My understanding is you have a list of items you want to be present in all tickets that are created in your JIRA. - correct me if I misunderstood here.
If so, you would need to:
The above steps is based on my understanding of what you would like to achieve. However as I asked, please clarify what you meant by a template and also how are issues being created in JIRA?
Thanks.
I didn't get how I can create a custom field and then add it to new screen, so I could create issues from this template. Could you provide a link explaining that?
How are you doing "templates"? What App have you added to Jira to do it?
Hi Maria
To be able to assist can you answer the question we have asked you first?
How are you creating said templates?
Without this we have no idea how to help.
Regards.
I created a custom field with checkbox in it. I would like to do an issue type with this customizable checkbox. So when I choose this issue, The checkbox is already there.
I need:
1) understand the dependency between screens - fields - issues.
Do I need to customize fields first, then implement that in the screen, associate the screen with the project? Where is the issue type in this case?
2) add the dates to the sub-tasks in my issue, when I am creating them via fields?
3) or fields are not issued for issues ? And I need to create issues first and then implement them in fields?
You still have not told us what you mean by "template"?
Or do you just mean "a default value for a field when I create an issue"? Defaults can be set under the field context configuration (admin -> custom fields -> your field -> configure)
Your understanding of the above is mostly correct.
