×Hello,
I need to import json file with custom field which have multiple value.
This is my labels field get from extract :
I tried this code to create a custom field with several values from a list :
And I get the followed error (line 76 = Label1,) :
Do you know which syntax to use ?
Thanks in advance for all the helps.
The format for custom fields of certain field types are mentioned here
