×Is it possible?
Currenly Jira projects have fields such as:
Project,Key, Project type, Project lead, Project category and URL
Can I add more?
You can't do this off-the-shelf. There are no "project custom fields" built into it.
There is a nifty little app called Profields that provides this sort of functionality.
Thank you @Nic Brough -Adaptavist- for the mention, Yes you can do a lot of thing related with Project Level fields and even with Projects using Profields @Pav Kryv
You can try it and contact with us if you have any additional questions. The support team will be pleased to help you.
Cheers
Thank you guys. I'll try it on Monday!
Jira allows you to add custom fields. You can learn more here: https://confluence.atlassian.com/adminjiraserver/adding-a-custom-field-938847222.html Custom fields can be added and associated with all projects or a single project. https://confluence.atlassian.com/adminjiraserver/custom-fields-with-global-contexts-956713282.html
