×Hello,
I am working on creating custom fields in JIRA SM. My requirement is following.
There are 2 fields - FieldA and FieldB.
When I select a particular value in FieldA, FieldB should pop up with a set defined list of values, and when I go back and select a different value in FieldA, the feildB should reset and allow me to select a different value for it.
I have tried achieving these using behaviours in scriptRunner but I have encountered the following problem -
1. It doesn't work on view screen. It only seems to work on create/edit screen.
2. When I change the value in FieldA, FieldB doesn't reset to default.
Using native Jira DC features you can't define dependency between two separate fields.
Nevertheless, ScriptRunner allows you implement so-called behaviors. Behaviors can implement what you requested here. This article is a good starter: https://library.adaptavist.com/entity/control-field-selected-checkbox
@Aron Gombas _Midori_ Behaviours doesn't work on view screen. If I want to achieve this feature on inline fields, I cannot do that using behaviours. It only works on create/edit screen.
@Kumar Ankit Let me summarize your requirements. When in "view" mode you click a "select" field to indicate that you want to change its value, you want another, separate field also turn to "edit" mode immediately?
Honestly, to me it sounds a bit weird interaction...
But, if that's what you need, I can't help I am afraid.
Hi @Kumar Ankit ,
You can create a Cascading (List Type) custom field in your JSM which will fulfil your requirement.
Kindly follow :
Harshit
Hello @Harshit Grover ,
Thanks for the quick response. I tried using your approach, but this method only allows me to select certain values based on the first value selected, all in the same field.
However, what I want is to have the second value to be a different field altogether. For ex - If test dependent field == Test1, then a new field called - Test123 == Value1.
