How to create issues and its sub-issue "in transaction"?
Jan Krystof June 12, 2014
I need to create valid issue and it's subissue. However, in order to validatea sub-issue I need to provide it's parent ID (I am using
issueService.validateSubTaskCreate
). Problem is, that the parent issues has not been created yet: I want to create parent issues as soon as I know, that validation procedure for sub-issue will succeed. So I want to work within a kind of transaction.
Thanks for any hints!
Jan
Timothy
June 12, 2014
This is your catch 22 then. You cannot create a sub task if you don't have the parent task.
Timothi, I understand that.
My question actually was, whether I can validate creation of issue "P" with children "C1" and "C2". I have all parameters (summary, issuetype, etc.) needed for creation P, C1 and C2.
Jan
Timothy
June 13, 2014
Nope. Cause C1, C2, ... needs a valid P issue id/key.
Jan Krystof June 23, 2014
OK,
Thanks Timothi!
I will live with that...
