I want to programmatically create issues and assign, inside a listener, for example, a VersionCreateEvent. How to do that? Will that be possible with the REST API?
Here code exmple for Java API. Try to adopt it for listener
package IssueCreation import com.atlassian.jira.bc.issue.IssueService import com.atlassian.jira.component.ComponentAccessor import com.atlassian.jira.issue.Issue import com.atlassian.jira.issue.IssueInputParameters import com.atlassian.jira.issue.index.IssueIndexManager import com.atlassian.jira.user.ApplicationUser import com.atlassian.jira.user.util.UserManager import com.atlassian.jira.util.ErrorCollection /** * Created by VZverev on 10.06.2016. */ //Issue issue = null; IssueService issueService = ComponentAccessor.getIssueService(); IssueInputParameters inputParameters = issueService.newIssueInputParameters(); UserManager userManager = ComponentAccessor.getUserManager(); inputParameters .setProjectId(issue.getProjectId()) .setIssueTypeId("11504") .setReporterId(ComponentAccessor.getJiraAuthenticationContext().getUser().getName()) .setSummary(issue.getSummary()) .setAssigneeId(userManager.getUserByKey(issue.getAssigneeId()).getName()) ApplicationUser curUser = ComponentAccessor.getJiraAuthenticationContext().getUser(); IssueService.CreateValidationResult createValidationResult = issueService.validateCreate(curUser, inputParameters) if(!createValidationResult.isValid()){ ErrorCollection errorCollection = createValidationResult.getErrorCollection(); return errorCollection.toString() } else{ IssueService.IssueResult createResult = issueService.create(curUser, createValidationResult) IssueIndexManager issueIndexManager = ComponentAccessor.getIssueIndexManager(); issueIndexManager.reIndex(createResult.getIssue()) }
@Vasiliy Zverev , Writing the same inside an event listener would work, right?
@Shagufta Gurmukhdas, yes it should.
Note that all values are set into inputParameters object.
