How to create more than 50 custom fields in Jira???
Akhilesh Mishra
April 17, 2023
I am getting a restriction message for 50 fields. while I need to create around 4x to 5x custom fields. How can I increase the count limit??
Doug Winenger
I ran into the same issue in a team managed project.
Today, I specifically set out to test the ability to share global custom fields.  I accessed the target project and added a new custom field to re-confirm the "50 field" limit/error ( I had previously gotten the error upon attempting to add an additional field).
However,  I did not get the error this time.  I added 72 custom fields specific to the target project and I'm still not getting an error.
The behavior is really inconsistent.   I'm going to reach out to clow@atlassian.com to inquire.
Ollie Guan
Hi @Akhilesh Mishra ,
You can create up to 50 custom fields in your team-managed projects.
https://support.atlassian.com/jira-software-cloud/docs/customize-an-issues-fields-in-team-managed-projects/
company-managed projects maybe more suitable for you and it supports more custom fields.
Migrate between team-managed and company-managed projects
https://support.atlassian.com/jira-software-cloud/docs/migrate-between-team-managed-and-company-managed-projects/
Fabio Racobaldo _Herzum_
Hi @Akhilesh Mishra  and welcome,
there is a specific restriction for team-managed projects. Please take a look here https://jira.atlassian.com/browse/JRACLOUD-78719
Atlassian update (Feb 2023)
Hi everyone, thank you for your interest on this ticket. We’ve recently introduced the ability to re-use global custom fields in team-managed projects, which allows you to effectively use more than 50 custom fields in team-managed projects. This comes with the added benefit of being able to re-use fields across projects. Global custom fields also have a higher limit of options (note that we do not recommend having too many as it can affect performance of your Atlassian Cloud Instance). If you have a specific need to create more than 50 team-managed fields, please reach out to me at clow@atlassian.com so that I can understand your use cases better.
note: functionality of fields created in team-managed projects still remain the same and will not show up in other team-managed projects. Please feel free to reach out with any feedback on this new feature.
Hope this helps,
Fabio
FREE
