How to create recurring issues on Jira OnDemand?
Arnold Arguello
April 14, 2014
Jira Support,
I’ve been trying to figure out on how to create recurring issues on Jira OnDemand, the information I found so far requires some coding knowledge (refer to link below). Please let me know if there’s an easy way to install this functionality without having to code.
https://answers.atlassian.com/questions/173546/create-recurring-issue-for-jira-ondemand
Thanks for your support.
AA
CodeDoers
CodeDoers
Nic Brough -Adaptavist-
April 14, 2014
No, you can't install anythign to do this.
The answer you've found basically involves scripting an external process which will create issues, which you then add to a scheduler of some sort. The Jira CLI addon it mentions makes external scripting a lot easier, but isn't strictly essential for it. However, the principle is the same - write an external process and run it regularly.
Personally, I did a one line curl command and ran it in a "cron" job on a server, but it wasn't complex. There's some examples at https://confluence.atlassian.com/display/DOCSPRINT/The+Simplest+Possible+JIRA+REST+Examples
